Mirrors detected anomaly traffic to the mirror port.
| port_list | Specifies the list of ports. |
N/A.
The command mirrors detected anomaly traffic to the mirror port. You must enable a mirror port and enable protocol anomaly protection on the slot that has the port to be monitored before using this command. After configuration, only detected anomaly traffic from these ports are dropped or mirrored to the mirror port, and legitimate traffic is not affected.
This command takes effect after enabling anomaly-protection.
This command was first available in ExtremeXOS 12.0.
